Driveshaft lengths.
Old Jan 19, 2014 | 11:39 PM
Warferox-Veritas's Avatar
Warferox-Veritas
Default Driveshaft lengths.
Ok so i have been searching and searching and keep getting conflicting statements and vague answers. So here goes.
I have a 98.0 Dodge Ram 2500 12v Cummins 4x4 quad cab short box with auto tranny. I want to do a NV4500 swap and i am acquiring all the necessarily parts to do so. I am using a donor truck but it is a 2wd C&C 1ton.
I cant seem to find a reliable answer to whether or not i will need new driveshafts/driveshaft. I have an NP241DLD which i will be converting with a 29 spline input shaft.
Will i need new shafts? It would make sence that the t-case would not end up in a different position front or back or the shift lever would have to be changed... i have to convert my NV4500 to a 4x4 tailhousing and output shaft so i cant measure its final length yet but i understand it will be about 6 inches shorter then my 47RH auto. Being a short box my rear shaft is a solid one piece.
If anyone would be so kind as to clarify for me i would appreciate it. It would be nice and i imagine many others would find it useful if there is a list out there of all the length combinations. ~reg cab LB auto 2wd= xx length ~quad cab sb 4x4 manual= xx length and so on.
Thanks
Old Jan 20, 2014 | 10:38 AM
Not sure the t-case will bolt to the back of the 2wd trans, without doing some mods there. Might require a different output shaft......
Old Jan 20, 2014 | 01:38 PM
Warferox-Veritas
I have to convert the 2wd trans to 4x4 tailhousing and shaft (good excuse to put in an updated full splined shaft) i also have to change the input shaft of the t-case to match.
Old Jan 20, 2014 | 02:36 PM
Measure the length of the new trans/t-case, vs. the old trans/t-case, if they are within about an inch of each other, you should be OK.
Old Jan 20, 2014 | 03:11 PM
merc225hp's Avatar
merc225hp
Info for 135" wheelbase
1995 RClb, 4wd, 46rh, 241 dld, Dana 60 weld to weld 49”
Info for 139" wheelbase
1996 Ccsb, 4wd, 46re, 241 dld, Dana 60 weld to weld 58”
1996 Ccsb, 4wd, 46re, 231 dld, Dana 60 weld to weld 58”
1996 Ccsb, 4wd, 46re, 231 dld, 9.25 diff weld to weld 60”
Old Jan 20, 2014 | 10:58 PM
Warferox-Veritas
Qcsb, did you mean 2 door ext cab? quad cab came out in 98.
Old Jan 20, 2014 | 11:01 PM
merc225hp's Avatar
merc225hp
As far as I know that makes no never mind. But yes Club Cab, 139" wheelbase.
