Tire size question
Old Jan 20, 2014 | 01:49 PM
emattern06's Avatar
emattern06
Default Tire size question
Ok so I have a 2-2.5" level 2001 ram 1500 and I just bought 315/75/16 mud tires for it and I was wondering if I could fit them on the stock alloy wheels without any harsh rubbing issues. Anyone running this setup?
Old Jan 20, 2014 | 02:34 PM
Only if that's an off-road edition....
Old Jan 20, 2014 | 03:10 PM
emattern06's Avatar
emattern06
Nope...
Old Jan 21, 2014 | 01:45 PM
Johnn123's Avatar
Johnn123
Nope. Need a 5" lift minimum and 16x9" wheels, not sure what offset and back spacing.
Old Jan 21, 2014 | 07:01 PM
Thornloe Pride's Avatar
Thornloe Pride
You can run 33s but not 35s. Need a bigger lift for 35s. If you MUST fit them and are on a budget, get a 3 inch body but personally I would get a 5 inch suspension lift.
Old Jan 27, 2014 | 06:45 PM
Josh Rokusek's Avatar
Josh Rokusek
I have a 2001 1500 with just a 2.5 leveling kit up front and load lever springs in the back and I have 315/75-16 mt tires on my stock rims only problem I had was I couldn't turn full lock it would hot the lower track bar otherwise no problems! I got a set of inch wheel spacers problem solved..
