Hello
Old Jan 20, 2014 | 04:17 PM
hotrodsunlimited's Avatar
hotrodsunlimited
Cool Hello
I am new on Dodge Forum but I have owned a couple of Dodges. The one I have now is a 1995 2500 4x4 with a flat bed.Other than the the body, here is the two things I am having a booger of a time figuring out---First--The head light switch had the typical burn out problem. I changed the harness and triple checked the wires before I soldered them together. When the lights are turn on, the park and dash lights will only work if the switch is slightly push in, the the head lights will go out. The dimmer switch functions properly....Second--She cranks but will not fire at the coil. It has fuel pressure. compression and cam timing. it is said no question is stupid, I will cautiously say no answer is stupid,---- BUT---PLEASE keep it civil and I look foward to talkin to yall.
Old Jan 20, 2014 | 04:45 PM
merc225hp's Avatar
merc225hp
For spark problem most likely CKPS is your issue, pass side of the motor behind the head, top of the bellhousing. Hopefully a mod will move this thread to the tech area for you.
Old Jan 21, 2014 | 04:54 PM
hotrodsunlimited
Thank you.
