gear ratio question.
Old Jan 20, 2014 | 10:43 PM
giulietti07's Avatar
giulietti07
Default gear ratio question.
Hi I own a 97 ram 1500 slt Laramie with the tow package. Could someone tell me if the gears that came in the tow package are 3.90s or 3.92s bc the sticker under the hood is like wiped off right after the 3.9... Rear is a 9.25. Reason im asking is bc the P.O. had the rear replaced amd they put wrong gears in the rear, but when looking for ring amd pinion gears online they sell both the 3.90 and 3.92 I believe. So which is a factory gear?
Old Jan 20, 2014 | 10:50 PM
Arde's Avatar
Arde
3.92 is factory gear, 3.90 will work out OK.
Old Jan 20, 2014 | 10:59 PM
merc225hp's Avatar
merc225hp
^^^ +1 Need a rear set I am about to throw out/ in the trash just what you need.
Old Jan 21, 2014 | 01:26 PM
Johnn123's Avatar
Johnn123
Is it 4x4? If so whats in the front? 3.90 and 3.92 are close enough it would not make a difference.
Old Jan 21, 2014 | 03:40 PM
Get a build sheet for your truck, that will tell you exactly what the ratio was from the factory. Match front and rear. Sure, the .02 difference wouldn't matter over much.... but, even under normal off-roading, you will have a bit of a bind on the driveline. Best to match the gears, and call it a day.
Old Jan 21, 2014 | 05:19 PM
dakotaff's Avatar
dakotaff
In the areas that say "Subject" and "Description", put "Vehicle Build Sheet".
Build Sheet Request
