need some advice from yall!
Old 01-30-2014, 01:37 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
I'd suggest taking you uncle with you to look at the truck and to help you negotiate with the seller. Also, if you plan to have your uncle perform the repairs on your truck, he can give you an idea as to whether or not its a vehicle you should purchase or pass on.
Old 01-30-2014, 09:33 AM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
This a really good idea. Maybe he will have a scanner he can plug into and see if there are any codes stored in the computer that haven't lit the check engine light, not all do.
Also is this an automatic trans? If so check out this link for list of parts for rebuild https://dodgeforum.com/forum/2nd-gen...fo-only-6.html post numbers 56-63.
Dave
Quick Reply: need some advice from yall!
