Wire Color help
Old Feb 2, 2014 | 04:54 PM
Billy Sombrero's Avatar
Billy Sombrero
Default Wire Color help
I just bought a 2000 Ram 1500 5.9. After going through everything I noticed 2 wires were cut. I am not sure if it was intentional or not and everything on the truck seems to be working properly, so that is my hesitation to reconnect them. I thought maybe someone might be able to tell me what these wires are. There are both at the firewall and going into the PCM. One wire is white with a green stripe, the other is yellow with a black stripe. Any help would be greatly appreciated as I have search the forum and the internet for about 2 hours and I am out of patience! Thanks again!
Old Feb 2, 2014 | 05:19 PM
Scoty89's Avatar
Scoty89
In PCM connector 1 (Black) there is a Yellow/Black wire for the Idle Air Control #2 driver Pin 10 . In Connector 3 (Also Black) Pin 10 is showing White/Dark Green for the Leak Detection Pump Solenoid Control. Connector 1-3 is labeled from right to left. Meaning connector 1 is the one on the right and 3 is on the left. This is what is showing in service information from Chrysler.
Old Feb 2, 2014 | 05:21 PM
Yellow with black trace in C1 goes to IAC...... does your truck control the idle properly? CEL on? IAC codes??
There is a white with dark green trace in C3, that goes to the leak detection pump?
someone is faster on the lookup than me.
Old Feb 2, 2014 | 11:08 PM
Billy Sombrero
I do have an IAC code and figured one of those wires was probably an IAC issue as the code kept coming back even when I unplugged the thing. Thanks a lot for your help.
