Help
Old Feb 12, 2014 | 02:28 PM
drk5ide's Avatar
drk5ide
Then you need to fix that first.
It ran like that for 3 years no problems I think the plug is jacked. I would like to fix the not being able to drive it problem lol
Old Feb 12, 2014 | 03:54 PM
Need to be able to talk to the PCM, to see what IT thinks is going on. Makes troubleshooting MUCH easier.
The service manual has a pinout for the diagnostic port. See which wires aren't doing what they should.
Old Feb 18, 2014 | 11:41 AM
drk5ide's Avatar
drk5ide
Ok still no luck re-terminated the obd-II plug still cant get a read checked all fuses and wires nothing broke, shorted or missing. On the plus side the truck started running right so now I am $^&@ed because I have no idea what was going on with it.
Old Feb 18, 2014 | 04:25 PM
Try a different scanner?
Old Feb 19, 2014 | 12:53 PM
drk5ide's Avatar
drk5ide
Used 3 so far a cheap blue tooth elm 327, actron 9550, and a snap-on modis
Old Mar 22, 2014 | 11:42 AM
drk5ide's Avatar
drk5ide
ok got it worked out turn out to be a bad catalytic converter still cant get it to scan I have checked everything and cant figure it out.
Old Mar 22, 2014 | 12:25 PM
Bad cat is most likely a product of the blown plenum. Bet the front O2 isn't in the best shape either.
Grab the appropriate service manual for your truck, check the wiring diagrams. See what's up with the data port.
Old Mar 22, 2014 | 04:41 PM
You must not have emissions inspections in your area. They'd fail anything they can't connect to here.
Old Mar 24, 2014 | 11:44 AM
drk5ide's Avatar
drk5ide
Yep no emissions and it is not throwing any codes. I just cleaned out all the pieces of cat and put the pipe back up. I have gone and check everything with the OBD-2 (wires, fuses, connectors, etc... )and there is no reason it should not be reading had two mechanics look at it and they cant figure it out. On the plus side the truck is running great.
