High Flow Thermostat.
Old Feb 14, 2014 | 01:50 AM
Ram Driver's Avatar
Ram Driver
Default High Flow Thermostat.
Has anyone ever used one of these high flow thermostats in there truck ?, what your opinion on them ?.
http://www.jegs.com/p/Stewart-Compon...61639/10002/-1
Old Feb 14, 2014 | 06:15 AM
RDuck's Avatar
RDuck
It'll give you the opportunity to say you have one. But it will do nothing for you.
Old Feb 14, 2014 | 06:19 AM
RDuck's Avatar
RDuck
I'm sorry.
Are you pulling 8000-10000rpm with a high flow water pump on your engine most every time you drive?
Then you probably are running just a restrictor plate anyways so putting a thermostat in will just restrict it more.
If that's what your looking for then yes. It will work for you.
Old Feb 14, 2014 | 08:25 AM
AtomicDog's Avatar
AtomicDog
I use a Stant 180 degree Superstat in my truck with a 5.9 magnum engine. They are very good quality thermostats, work well and are reasonably priced. I use that in conjunction with an all aluminum radiator (CSF 2969) and a stock water pump. Works perfectly.
Old Feb 14, 2014 | 08:52 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Be advised that coolant flowing too fast through the system will not properly cool the engine.
Old Feb 15, 2014 | 01:03 AM
Ram Driver's Avatar
Ram Driver
I know coolant flowing to fast through the cooling system won`t cool the engine properly. But, staying with a 195* thermostat that flows more coolant than a stock thermostat wouldn`t that help cool the engine a little better while still keeping a stock temperature thermostat ?. If that makes sense.
Old Feb 15, 2014 | 10:29 AM
AtomicDog's Avatar
AtomicDog
That thermostat you are looking at is made by Robertshaw. I used that style several years ago, but it is not readily available in this area anymore, since Stant makes its comparable SuperStat at half the price.
If you want to improve the cooling of your engine, install a good quality 180 degree thermostat.
Old Feb 15, 2014 | 09:18 PM
Ram Driver's Avatar
Ram Driver
Those of you using 180* thermostats in your trucks, how are they working out for you ?, any codes for the engine running to cold or any other codes ?. Im thinking of going with a 180* thermostat as long as it won`t cause any problems.
Old Feb 15, 2014 | 09:22 PM
Matt Nickerson's Avatar
Matt Nickerson
Stay with the 195. Unless you have an sct tuner or some other modification that requires cooler engine temps, you're wasting money.
Old Feb 15, 2014 | 09:45 PM
AtomicDog's Avatar
AtomicDog
I use a 180 thermostat - no problems whatsoever - no stray codes and good heat during the winter inside the truck. Engine is not SCT tuned to-date - no real mods other than shorty headers, double roller timing chain, plenum plate and a good tune-up.
