Weatherstrip Questions.
Old Mar 4, 2014 | 12:59 AM
JeremyMichael's Avatar
JeremyMichael
Default Weatherstrip Questions.
Okay, my Dodge is 14 years old, and from what I can tell one or two pieces or more of weatherstripping are missing from the truck, and I don't know if this is causing what I am about to ask, or if it's common. The weather stripping under the hood, in the corners of the cowl that close and seal the gaps between the cowl and the engine bay are both missing, will that cause harm in the future? Or is it purely for aesthetics to look nice?
And Also I am wondering if these pieces missing can cause so much water to run down inside of the car door area that is somewhat open to the elements where the door connects to the body, because this morning with all the ice and snow we had, my door was almost frozen shut because so much water was frozen over the hinges, is it common for water to just freely drain down that area? If not what can I do to prevent this lol.
Old Mar 4, 2014 | 02:26 AM
Ram Driver's Avatar
Ram Driver
I think what those seals do is keep the water from running under the hood and possibly down on to the door hinges. Those seals were missing on my 2000 ram when I got it, so I bought a new ones from LMC Truck, but there expensive, at $20.00 dollars each.
I havn`t put them on yet, because its to cold and wet to do it.
Old Mar 4, 2014 | 02:17 PM
JeremyMichael
The ones I am missing are the corner seals that lay at the very edge of both sides of the cowl in the shape of an L, I called the Dodge dealer and they said they had things called Cowl Vent corner seals, which I believe is what I am missing, and I am hoping that is what is allowing the water to drain into the door hinge area.
They are only about $6 each.
Old Mar 4, 2014 | 02:24 PM
Go and have a look if the dealer has them on the shelf.... see if they are the right ones. If so, snag 'em.
Old Mar 4, 2014 | 02:25 PM
JeremyMichael
Sadly they didn't have them on the shelf, they have to order them lol, so theyll be in tomorrow and i'll go check them out, could both of these be the possible reason so much water gets down into the door hinge area?
Old Mar 4, 2014 | 02:39 PM
Doubt it. The mount forward on the cowl, under the hood a bit. Water naturally drains down at the base of the windshield, and runs down the door hinge area. My daughters Corsica has the same issue, with the same results. The doors get frozen shut....
Old Mar 4, 2014 | 02:42 PM
JeremyMichael
Ah!, so is it a defect on my car or do most vehicles do it? And if my Dodge is or isn't the only one with the issue (lol) what is a good way to minimize the issue? If it's something that is designed to happen on a Dodge, or any vehicle for that matter I won't worry about it as much, but if it's not common, i'd like to take some measure to decrease the amount of water that get's down there lol.
You will have to forgive me for some of the questions I ask, This is my first vehicle and I am slowly learning as much as I can, therefore I ask a lot of questions lol.
Old Mar 4, 2014 | 02:43 PM
Don't think there is a whole lot you can do about it, aside from parking inside.
Old Mar 4, 2014 | 02:46 PM
JeremyMichael
Sadly that isn't an option lol, I may look into a truck cover >.<, so do you have the same issue with your Dodge?
Old Mar 4, 2014 | 05:03 PM
Mine gets parked in the garage.
