1995 Dodge Ram 1500 5.2 fuel pressure problem
Old Mar 5, 2014 | 08:45 PM
Troydavis's Avatar
Troydavis
Default 1995 Dodge Ram 1500 5.2 fuel pressure problem
Hi guys I have a 1995 Dodge Ram 1500 5.2 . Fuel pressure is 20psi when you put the truck in gear and step on the brake the truck dies. We have put 2 fuel pumps in, same problem 20psi. When I put 12 volts to the pump I can get 35 psi at th pump. PLEASE HELP!!!!!!
Old Mar 5, 2014 | 09:08 PM
You should have right about 39 PSI at idle.
Are you buying airtex pumps by any chance?
Moving this to the right section.
Old Mar 6, 2014 | 06:48 AM
Troydavis's Avatar
Troydavis
yes both have been airtex pumps
Old Mar 6, 2014 | 10:03 AM
And there is your problem. Airtex has an absolutely horrid reputation. Go with the Delphi, or Denso pump.
Old Mar 6, 2014 | 06:52 PM
Troydavis's Avatar
Troydavis
We were able to fix it today found out we were loosing the ground to the pump ran a new ground and took care of the problem
Old Mar 6, 2014 | 07:30 PM
If you still have an airtex pump in there, you will get to do this again in about a year.... they are terrible.
