Carbed magnum 408
Old Mar 12, 2014 | 12:53 AM
mccart's Avatar
mccart
Your good, I didn't mean it to sound the way it did either lol to put it this way. I'm starting college this fall and am on a fairly limited budget. And want something that I can go have fun with and still drive. Only reason for building a 408 is that i already have a block and getting the crank from a buddy that built a 408 a few years ago
fuel injection:
Intake $700
Tb $250
Injectors $300
Tune $500
Wideband o2 $300
Carbureted motor:
Intake $300
Carb $400
Stuff to make it all work, maybe another couple hundred.
Old Mar 12, 2014 | 02:22 AM
Hahns5.2's Avatar
Hahns5.2
An AEM wideband is like $165. 4bbl M1s can be had all day long for sub $350. Modified injectors from FIC (I've been using a set for years) for $240. Over $500 less than you thought.
With a carb you will need a new fuel system and distributor at least.
Old Mar 12, 2014 | 07:42 AM
mccart's Avatar
mccart
Fuel system is fine and I'm gettin a msd system anyway
Old Mar 12, 2014 | 03:11 PM
Hahns5.2's Avatar
Hahns5.2
Well good luck pumping 49PSI into a carb.
Old Mar 12, 2014 | 03:13 PM
That's what return style regulators were invented for.
Using a non-return regulator would smoke the pump in relatively short order.
Old Mar 12, 2014 | 06:18 PM
aofarrell2's Avatar
aofarrell2
There are two good regulators to step down EFI pressure to carb, I have the returnless type. It will not smoke the pump, because it is still passing the same volume as a EFI system, thus providing the same amount of cooling. In other words, it is acting just like a fuel rail would, taking the same amount of fuel, leaving the same fuel pressure in the line... I have approx. 2K on my setup with no problems.
However, I would recommend a return type for anyone trying to do carb. It is much easier and more precise to use than a returnless.
Old Mar 12, 2014 | 06:38 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
fuel injection:
Intake $700
Tb $250
Injectors $300
Tune $500
Wideband o2 $300
Carbureted motor:
Intake $300
Carb $400
Your prices are a little high for the EFI stuff. But the BIG ONE is that you left out a lot of stuff you're going to have to buy for the carb. New distributor, linkage, external voltage regulator and other things I'm sure I'm forgetting now.
I understand being on a limited budget and am not trying to be an ***. I hope it all works out for you. EFI or Carbed have fun with the 408.
Old Mar 12, 2014 | 11:29 PM
mccart's Avatar
mccart
The reason I didn't put distributor in is because either way it goes it's getting a msd distributor and coil
Old Mar 13, 2014 | 02:16 AM
Wildman4x4nut
Veteran: Army
I don't think you can run the MSD distributor if you keep the EFI. If you can I sure would like to know how.
Old Mar 13, 2014 | 12:37 PM
crazzywolfie's Avatar
crazzywolfie
fuel injection:
Intake $700 re use the stock intake free
Tb $250 you can get them from 1999blkdakrt on ebay for less than $150
Injectors $300 you can get a rebuilt set for less than $150
Tune $500
Wideband o2 $300
Carbureted motor:
Intake $300
Carb $400
ignition/charging system $400-700
fuel pressure regulator $100
fixed. converting to carb is not cheap. there is also other thing i may be missing. unless your truck is carbed it is a waste of money coverting. it will also lower the resale value of the truck if you ever need to sell it.
