lucky me.... brakes are GONE
Old Mar 8, 2014 | 05:56 PM
cj5orion's Avatar
cj5orion
Default lucky me.... brakes are GONE
So....This morning,my brake pedal starts feeling a lil "spongy"
get home,park it,bear down on the pedal,look underneath,no leaks.
OK....maybe some air got in the lines ?
take it down to a shop,pads and rotors OK,cant bleed the lines....only a dealer can do that with a scanner.They put they're scanner on it....thing lights up like a xmas tree,maybe half doz codes related to brakes n sensors.
All of sudden.....NO BRAKES AT ALL.
had to drive her home using side streets,puttin in nuetral,using the emergency brake.
Damn....jus put a lot of $ into her on that vinyl wrap n suspension
Old Mar 8, 2014 | 06:01 PM
stewie01's Avatar
stewie01
The shop wouldn't bleed the brakes because only a dealer with a scanner can do that? WTF?
Any brake fluid in the reservoir? Tried bleeding them yourself?
Old Mar 8, 2014 | 06:27 PM
cj5orion's Avatar
cj5orion
yea reservoir's good.
IF.... I got an air bub in the lines....it "snuck" in there somehow ?
brakes were fine last week,this jus came up.
possible abs control module ???? somewehere around $1500 smacks Plus DEALER PRICED LABOR CHARGES ! plus not being able to work while the trucks down
OOOOOHHHHHH ! LUCKY ME !
Old Mar 8, 2014 | 06:33 PM
ReadRam's Avatar
ReadRam
Check your vacuum hose and check valve at booster. And yeh, that makes no sense about needing a scanner to bleed the brakes. Or your master cylinder is bad. Or a bad leak on a line or wheel cylinder??
Old Mar 8, 2014 | 06:36 PM
cj5orion's Avatar
cj5orion
vacuum !! hmmmmm...... possible
otherwise I'm stuck till Mon morn
Old Mar 8, 2014 | 06:42 PM
Are any of the lites on? ABS? Brake?
Chances are, the line going above the gas tank blew. It won't always show up on the ground right away.
Don't need a scanner to bleed the brakes either.
Think I would crawl under there, and closely inspect the full length of the rear brake line, pull the drums, and see what you find.
Old Mar 8, 2014 | 07:12 PM
cj5orion's Avatar
cj5orion
yea...jus went thru my manual...bleed the lines like any other
yea "brake" lite is on
gonna go check that line
Old Mar 10, 2014 | 10:53 PM
cj5orion's Avatar
cj5orion
master cylinder was all,,,,, NO DEALER ABS CRAP
put new pads in all around while I was there
bled everything
rock n roll.....ready to go
