how much lift
Old Oct 13, 2005 | 03:54 PM
ilovemyv10dodge's Avatar
ilovemyv10dodge
Default how much lift
k i got a 1996 dodge 2500 long box with the auto and v10.
i want to lift it with a suspension lift but, how much can i go with stock drivelines? if i have to modify the drivelines, how much dose that usualy run
ive lifted fords before but not dodges
thanks
Old Oct 14, 2005 | 04:15 PM
richardmoore's Avatar
richardmoore
Default RE: how much lift
I was told that 5 in was the highest you could go. Any higher and you would have to get custom driveshafts made and that can't be very cheap.
Old Oct 15, 2005 | 01:08 AM
4DrMopar's Avatar
4DrMopar
dude, drive shaft run ABOUT $250 each,which honestly isnt bad for what they are..
Old Oct 16, 2005 | 12:52 AM
Uggly's Avatar
Uggly
I have the 5 1/2" skyjacker susp lift with a 2" leveling kit.
No vibrations.... smooth as stock.
My last dodge was a 2500 V-10
By all means go for it!
Old Oct 16, 2005 | 01:48 PM
Tani1500's Avatar
Tani1500
correct me if im wrong but cant you losen up your u-bolts on the axel and turn it so the u joints arnt on such a bad angle? I thought i always see trail rigs like that.
Old Oct 16, 2005 | 02:56 PM
Uggly's Avatar
Uggly
Most Suspension lift kits come with a wedge that goes between the leaf pack and the axle.
This corrects most of the the diveshaft angle problems in the rear.
You cannot do this in the front due to steering geometry.....the truck would wander side to side down the road from negative camber.
This was not a problem with my '98 1500. After the 7" lift I was able adjust the the lower control arms forward for positive camber and the truck drives great and still no drive shaft vibrations.
Replace the factory steering stabilizer with a dual steering stabilizer and you should have no problems.
Old Oct 18, 2005 | 01:05 AM
richardmoore
$250 is a really good price for driveshafts i didn't realize that you could get them so cheap. I was also wondering, with a 5in suspension lift are the brake lines front and rear on the 1500's long enough?
Old Oct 19, 2005 | 12:34 AM
Uggly's Avatar
Uggly
The lines are long enuf but skyjacker included new longer brackets.
Old Oct 19, 2005 | 09:09 PM
richardmoore
Thanks, I've been wanting to take my 3in lift off and go with a 5in along with my 3in body lift and run 38x13.5. Do you think that is enough lift to clear those tires. My wheels are 16x10 and I forgot the backspacing.
Old Oct 19, 2005 | 10:30 PM
Tani1500's Avatar
Tani1500
thanks, uggly i think i was on crack when i asked you that because i knew the anwser myself after i though about it. man you havent been on here in a while, hows the rig?
