I have a leak from the front pumpkin right at the drive shaft that goes to the trans. I was wondering if there's a seal there and if it's easy to replace. It's not the shafts that go to the wheels also. Just right in the back where the driveshaft goes in. Any input will help. Thanks
That would be the pinion seal leaking. Shouldn't be too difficult to replace. Just need the right the tools and some time. The procedure is marked out in section 3-66 of the 2001 service manual. You can download it from here
