97 Ram 3500 No Cruise Control
Old Mar 15, 2014 | 08:23 PM
Ron Wiles's Avatar
Ron Wiles
Default 97 Ram 3500 No Cruise Control
I am a newbe to the forum but would like to ask for help. I have no cc and when I try to turn it on the light on the cc switch does not light. wiring digaram says
fuse 10 powers the cc switch with a red wire, I have no red wire on the cc switch. I do have power at fuse 10 but no power at any wire in the cc switch, any one have any ideas.
Thanks Ron
Old Mar 16, 2014 | 10:09 AM
Yellow wire with red trace is power feed. Probably five volts, but, might be 12...
Pin 1 on the connector at the switch. (need to pull the airbag to test..... need to discharge the airbag module before you remove the bag itself. Just disconnect the battery, then wait ten minutes.
