please help with wireing anybody
Old Mar 17, 2014 | 02:18 PM
bigdad9418's Avatar
bigdad9418
I had a friend wire it up I will get under and look at wires and find out what wiresare hooked I know he said the 2 purple wires are not Hooked up
Old Mar 17, 2014 | 02:55 PM
dodgetrucker75's Avatar
dodgetrucker75
Originally Posted by bigdad9418
Ok but there's a sensor with 2 wires almost at the back of the transmission what is That its on the driver side what does it do
the two wire sensor near the rear is the transmission output shaft speed sensor, but its not what you need, the three wire plug you have is the vehical speed sensor, and no matter what wiring you have, that trans is not going to shift correctly or at all with the 94 wiring, the "variable force solinoid" needs to be regulated to be able to shift
