4x4 not working
Old Mar 20, 2014 | 12:55 AM
drtydn's Avatar
drtydn
Default 4x4 not working
ok so heres the thing, i need help. I replaced my acuator and i know it locks in, i also checked drive shaft and the transfer case seems to work. However, took my truck to a dirt lot turned the wheels and steped on it, 4x4 is not working. what could it be?
Old Mar 20, 2014 | 10:48 AM
What leads you to think it isn't working? Is the lite in the dash coming on?
Old Mar 20, 2014 | 12:12 PM
How does this prove 4x4 is not working?
Old Mar 20, 2014 | 06:44 PM
drtydn's Avatar
drtydn
not light in the dash is not working, I took the indicator switch off and tested continuity when I pressed on it with my finger.... it was "iffy," that told me something is wrong with that switch... as far as me taking my truck to a dirt road, turning the wheels and flooring it, I have always tested 4x4 this way (not for long periods of time) and always fling up dirt and/or jumped. none of this happened, just as if I was in 2h. I know the axle locks up due to the fact that when I had it on jack stands I had a buddy put from 2h to 4h to 4l, I would turn the tires to see if they both turned (different directions I might add because of the spider gears), when in 2h only one tire would turn freely at a time... I do not have enough jack stands to have all four tires off the ground.
Old Mar 20, 2014 | 06:47 PM
Jack up the front end. Put the T-case in 4wd, try and rotate the front driveshaft by hand. See what happens.
Old Mar 20, 2014 | 07:05 PM
drtydn's Avatar
drtydn
front drive shaft doesn't move.... im also thinking the vacuum switch migh be bad.... don't have as much suction in 4x4 as 2wd
Old Mar 20, 2014 | 07:14 PM
Or may have a bit of a leak in the line. Steel lines like to rust out......
Old Mar 20, 2014 | 07:28 PM
drtydn's Avatar
drtydn
ya know what, I completely bypassed that notion.... given the condition of my truck how I bought it, that wouldn't surprise me one bit.... ill have to do that payday (next Friday) and update you on how it goes
Old Mar 21, 2014 | 08:19 AM
ChillyPhil's Avatar
ChillyPhil
My 4H didn't work when I got stuck in 2wd. I put it in 4L and it worked right away.
Not sure if it didn't lock in the whole way in 4H or not. Shop said it worked good when they had it up on the lift.
Old Mar 21, 2014 | 10:57 AM
Ham Bone's Avatar
Ham Bone
I'd invest in posi lok to get rid of the troublesome vacuum system anyway. It's like 150ish??? I think
