need a little shock absorber help
Old Apr 1, 2014 | 10:07 PM
rockinH5's Avatar
rockinH5
Default need a little shock absorber help
I ordered some Bilstein 4600 shocks online, but what they sent me was the 5100 series. Since I don't want to messs with the hassle of returning these, I would like to try and install these if they'll work. Truck is a 99 Ram 1500 crew cab, 5.2L, 2WD on stock suspension with a 2" leveling kit?
Old Apr 1, 2014 | 10:41 PM
stewie01's Avatar
stewie01
What's the size difference between those and the old shocks? Mounting the same between the two?
If they're pretty close to the same size and they mount the same way it should work easy.
Old Apr 1, 2014 | 11:15 PM
rockinH5's Avatar
rockinH5
I think the only real difference is they were made for heavier applications. I don't really know that for sure though.
Old Apr 1, 2014 | 11:41 PM
sam3293's Avatar
sam3293
Well the 5100 according to bilstein is 4wd here is link.
http://cart.bilsteinus.com/search/mm.../drivetype=4WD
2wd recommended
http://cart.bilsteinus.com/search/mm.../drivetype=RWD
Old Apr 2, 2014 | 10:01 AM
stewie01's Avatar
stewie01
^^ If the 5100 is 4wd you'd probably never get that shock in place without having to let the wheel hang down over something.
The 4wd shocks are significantly longer than 2wd shocks.
Old Apr 2, 2014 | 10:09 AM
rockinH5's Avatar
rockinH5
appreciate the feedback.
I ordered them from 4wheelparts.com and the website shows these 5100's to be compatible. I guess I better measure the two and compare first.
Old Apr 2, 2014 | 10:12 AM
stewie01's Avatar
stewie01
Yea take one of the old ones off and set them side by side, see how much difference there is in length.
Old Apr 2, 2014 | 07:26 PM
rockinH5's Avatar
rockinH5
there's a substantial difference in size, so the local retailer is going to let me come in and swap them for what I need.
Old Apr 2, 2014 | 07:38 PM
stewie01's Avatar
stewie01
^ Sweet.
Old Apr 8, 2014 | 10:01 PM
rockinH5's Avatar
rockinH5
can someone confirm the nut/bolt size on the shocks for 99 ram 2WD?
