Getting water pump off without special tool.....
Old Apr 3, 2014 | 06:41 PM
Twmays's Avatar
Twmays
Originally Posted by HighwayDUB
What I mean is what did you use to hold the water pump pulley still, while you tightened the fan nut? Did you just put the belt back on first and use the tension from the belt to hold the pulley still?
Oh. I actually have big enough hands that I just got a good grip on the pulley and gave it a good cinch.
I did have to do it twice though. The first time, I thought (as has been mentioned here) that the reverse threads would be enough to hold it on without much pressure, but the first time I started it up the fan flung right off. Damn lucky I didn't damage the radiator.
Definitely want some amount of torque to home it in place. Either use a strap wrench or find some other way to hold it in place and tighten it down.
Old Apr 4, 2014 | 06:27 PM
HighwayDUB's Avatar
HighwayDUB
Originally Posted by CSDavies26
Amazon.com: Lisle 44180 Fan Clutch Spanner Wrench: Automotive
That's the tool you need. I'd say that $35 is better than $90 any day...I have the same wrench and it works like a charm...saves a ton of hassle trying to use strap wrenches and other tricks.
thanks, I might pick up that tool.....
and thanks for all the replies!!
