Rocker panel rust repair..please help
I have a 95 dodge 1500 standard cab 4x4 that is well rusty. now when it comes to reparing the rust on the out side its fairly easy to me cut out old put in new that goes for rockers and cab corners but...what i have found is that the inner part of ther rocker or the part you see when you cut away the outer rocker is very rusty and needs replacec or fixed what im wondering is what is the best way to go about this is there a patch panel for the internal as well or will i have to fab something up and also for the cab mounts i found a website were i can buy new ones has anyone on here ever replaced those is it just drill out old spot weld and then re weld just curious befor i go and start tearing her down thanks
