code 32: EGR
Old Apr 8, 2014 | 11:45 AM
jtcowan's Avatar
jtcowan
Default code 32: EGR
I have a 95 ram 5.9L. I have a code 32. has anyone with that code experience a problem other than an EGR valve?. the engine runs smooth but the engine light keeps coming on. tks
Old Apr 8, 2014 | 01:28 PM
Short or open in the EGR solenoid circuit.
That's an electrical problem. Is the solenoid plugged in?
Old Apr 8, 2014 | 02:07 PM
jtcowan's Avatar
jtcowan
tks for the reply. I am going to start working on it tomorrow. with the egr behind the intake manifold, it is hard to examine. think I will take off the shroud and fan so I can stand more comfortably.
Old Apr 9, 2014 | 01:53 PM
jtcowan's Avatar
jtcowan
Default may have found the problem
I verified that the electrical connection was plugged in to the solenoid. I checked the vacuum line connections and discovered that the connections between the solenoid and valve were backward (I compared my connections to the connections on new valve/solenoid found on line). about 800 miles ago I replaced the intake manifold and plenum gaskets and apparently hooked them back up backwards. took it for a short test ride and no "check engine" light. it will take more driving to confirm it is fixed but I am hopefully optimistic.
Old Apr 9, 2014 | 02:35 PM
Hopefully that will take care of it.
Old Apr 14, 2014 | 09:20 PM
jtcowan's Avatar
jtcowan
well, the check engine light came back on. I removed the egr valve, cleaned it and reinstalled it on the engine. light came back on. replaced egr valve with new one today. just returned from a 20 mile trip. no light. hopefully it is fixed, if not, I will post again.
