Fan clutch and cel light?
Old Apr 11, 2014 | 12:08 PM
ReadRam's Avatar
ReadRam
Default Fan clutch and cel light?
A recently replaced fan clutch went bad again yesterday. Was warrantied by shop so no problem there. The weird thing is I got CEL when I got on the highway. There were two codes , one for abs sensor, and for a knock sensor. I told the mechanic it doesn't have a knock sensor. He just looked puzzled. I wanted to find out why the motor lugging to spin bad fan clutch set a code. The abs light never came on at all. I don't get the connection and it isn't that important.
Another question..is it fact or fiction that laying the fan and clutch in horizontal position can allow the silicone to leak into bearings. The fan clutches come horizontal in a box when they are new.
I just had mine off doing plenum a few weeks ago and am wondering if that maybe what happened or was it just a bad part to begin with. This mechanic never heard anything about keeping the fan vertical when removing.
Old Apr 11, 2014 | 12:56 PM
Yeah, codes for items that don't exist are rather puzzling..... Clear the codes, drive it for a while, see what happens.
Old Apr 11, 2014 | 09:33 PM
Ram Driver's Avatar
Ram Driver
It doesn`t matter which way you lay the fan clutch, it shouldn`t have any effect on it at all.
Old Apr 12, 2014 | 04:20 AM
ReadRam's Avatar
ReadRam
Another example just because someone wrote it on the web doesn't mean it's true. I've read posts on here and several info articles about ruining fan clutches by laying them flat after removing to perform other engine repairs.
Old Apr 12, 2014 | 10:53 PM
Ram Driver's Avatar
Ram Driver
Just because you read it on the web doesn`t mean it true, that for sure.
Ive removed several fan clutches from vehicle over the years to replace water pumps and other things, and ive never had one go bad yet.
