ignition control
Old Apr 11, 2014 | 12:50 PM
ngmillar's Avatar
ngmillar
Default ignition control
Ok guys 2001 dodge ram 1500 here with a problem starting the truck. Ok so that red wire that goes from the black ignition box on the steering wheel has been broke for some time. My step dad fixed it when it first happened and was his truck but now its happened again and the connector isn't the right one so it won't stay in place and the wire is just long enough so any little movement knocked it loose. Well now I cant get it connected at all so im not sure what to do. Is there anywhere I can get the correct end connector that goes into the black harness or what ?
Old Apr 11, 2014 | 12:53 PM
Pic of your problem?
Maybe the dealer......
Old Apr 11, 2014 | 12:59 PM
ngmillar's Avatar
ngmillar
Ill get one in a few on my phone right now
Old Apr 11, 2014 | 07:57 PM
ngmillar's Avatar
ngmillar
Between my two jobs i haven't been home since this afternoon so no pictures yet but if it helps im looking for the wiring harness that goes from the ignition switch box to what I can only assume is the fuse box. The read wire on the far right is the one that is the issue hopefully i will have a picture soon
Old Apr 11, 2014 | 09:42 PM
Aren't those just spade connectors? Should be able to get them at any shop that has electronic parts.
Old Apr 11, 2014 | 10:29 PM
ngmillar's Avatar
ngmillar
Im thinking the same thing but the way they are designed from the factor is more of a square shape and it has a spot to be caught by a locking clip so it stays in the harness when I use a regular spade connector I cant get it to actually stay in place
Old Apr 12, 2014 | 07:57 AM
ngmillar's Avatar
ngmillar
Well I was able to use a spade connector sfter I did a little shaping so that it fit in the harness and had no problem sliding over the connection but it worked none the less
Old Apr 12, 2014 | 09:06 AM
Good to hear.
