my bad on 2nd post (newbee)
Old Apr 12, 2014 | 08:46 PM
glenmoudy's Avatar
glenmoudy
Default my bad on 2nd post (newbee)
On the po 255 it flashs 1/2/5/5 so I read codes for 96 ram 5.9 that's what it said checked 3 times but I will do again when I get off work.
Old Apr 12, 2014 | 09:50 PM
lance49726's Avatar
lance49726
You do not have a P0255 code. what you have is code 12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal). And code 55 End of error messages (If you get this only, no errors were found)
that info is from the 1996 factory service manuel
Old Apr 12, 2014 | 11:47 PM
Snowfan's Avatar
Snowfan
I picked up a code scanner from eBay for 15 bucks. It also clears codes. Well worth the money.
Old Apr 13, 2014 | 02:02 PM
glenmoudy's Avatar
glenmoudy
Default thanks
Will write back when I got it fixed invertently when I dropped tank I broke fuel line connentor but can fix that without any help . So what's the deal with these chips are they that good for 5.9 ?
Old Apr 13, 2014 | 03:39 PM
Snowfan's Avatar
Snowfan
Chips? Not sure what you are referring to. Performance chips? No good. The computer will work around it after awhile. To properly upgrade ecu function it needs to be re-programmed. Search SCT and Hemifever.
If you meant some other 'chip' disregard post.
Old Apr 13, 2014 | 04:07 PM
and it also depends on what year truck you have for how easy reprogramming is.
