stupid hub question
Old Apr 13, 2014 | 07:14 PM
Shaggy433's Avatar
Shaggy433
Default stupid hub question
I need new hub bearings on my truck but am not sure of which ones I need. How do I know if I have 2 wheel or 4 wheel ABS? Is there any difference on the brands? Timken, Moog/National? here are the ones Im looking at
MOOG/NATIONAL Part # 515038 Front; 4WD; 2-Wheel ABS
MOOG/NATIONAL Part # 515039 Front; 4WD; 4-Wheel ABS
I'm also replacing tie rods and not sure which ones I need. Looking to stick with Moog on these but on RockAuto i can't seem to find the Front Right Inner on there but they have 2 different part # for the left inner...
MOOG Part # ES3527 Front Left Inner (To Pitman Arm)
MOOG Part # ES3526 Front Left Outer
MOOG Part # DS1460 Front Right Outer
MOOG Part # DS1462 Front Left Inner
going by the part number, I would think that the last one is mislabeled but I have never worked on steering components so I have no idea whats what.
I have a 2001 1500 4wd with the 5.2 auto sport if that helps..
Old Apr 13, 2014 | 07:20 PM
Take a look under your hood, if you have the motor/controller for ABS, you have 4wal, if not, then rwal. Or, look at your front hubs from the back. If there is a wire going to them, that means 4wal. No wire: rwal.
Johnn123's Avatar
Johnn123
Get timkens for bearings.
I got a build sheet for mine and it told me 2w abs. Go and check and see if theres a wire hanging down or just a brake line. Extra wire will be 4w abs. IIRC only the slt laramies came with 4w abs.
edit: that ninja above me^^
Old Apr 13, 2014 | 07:24 PM
Shaggy433's Avatar
Shaggy433
ok I didnt see any wires going to them so I thought it was 2 wheel but i wasnt 100%.
Old Apr 14, 2014 | 12:55 PM
Shaggy433's Avatar
Shaggy433
any ideas on the steering components?
Old Apr 14, 2014 | 01:00 PM
Download the parts catalog from the faq section here, and it will give you a nice picture of what your steering linkage looks like. I *think* there is a possible upgrade for the steering... (going to a cross-over steering, instead of the Y type that is on there now.....) Might wanna check into that as well.
