Thermostat Gasket Leak, HELP!
Old Apr 13, 2014 | 08:51 PM
alaskaguy's Avatar
alaskaguy
Default Thermostat Gasket Leak, HELP!
So I recently bought my 1994 dodge 1500 and want to go through everything possible to put new. In this quest, I noticed my truck was always running around 220 degrees. I wanted to get it closer to 185-190. I bought a new thermostat and gasket and went to town. Took everything off, cleaned the surface, and replaced. When I went to add coolant, it seemed as though there was a huge leak, poring coolant on the ground. I went back cleaned everything back up and bought a new gasket and hi-temp rvt. I replaced it setting the adhesive side of the gasket on the thermostat and then hi-temp sealant. Tried refilling and now I still have a leak. It's not as bad, but still a leak. It seems as though the leak is through the adhesive/cardboard gasket. This is very frustrating! Does anyone have any ideas?
Old Apr 13, 2014 | 09:04 PM
rollinlow's Avatar
rollinlow
base of your housing may not be good may need to be cleaned up not allowing it to seal
Old Apr 13, 2014 | 09:53 PM
alaskaguy's Avatar
alaskaguy
I felt that I was able to get the housing super clean before reinstalling. It looked as though its never been changed before this. Could the housing be warped preventing a good seal? Or should I try not using a paper gasket at all and just use rvt?
Old Apr 13, 2014 | 10:18 PM
The bolt isn't bottoming out before the housing is sealing is it?
Old Apr 13, 2014 | 10:35 PM
alaskaguy's Avatar
alaskaguy
That I'm not sure of, ill check it out, any ideas of how to see for sure if it is or not?
Old Apr 14, 2014 | 02:07 AM
ReadRam's Avatar
ReadRam
Could try torquing it down a little more or just start all over again, making sure surfaces are good and clean.
