O/D off vs O/D on
Old Apr 14, 2014 | 02:52 PM
Thornloe Pride's Avatar
Thornloe Pride
Originally Posted by CSDavies26
I have 4.10s from factory (off road edition) and I run 285/70/17 toyo AT tires...my truck does just fine on all hills here in western PA...if I were towing anything, I turn OD off but otherwise I just let it roll...your tires are a little bigger than mine, but i still think the 4.10s would be better for you. I've heard some people even say that the 4.10s will do ok with 35s as long as you aren't towing.
After driving with 35s and 3.55 for almost a year I think I can say that yes 4.10s with 35s would be okay. For sure a LOT better than 3.55. If I had an ORE with 35s I wouldn't spend the money to switch to 4.56.
Old Apr 14, 2014 | 03:32 PM
snowboundrmk's Avatar
snowboundrmk
So to clarify the OD switch only controls the lockup of the converter in 4th gear? The position of the switch would have no effect for regular town driving in 1-3 gear?
Old Apr 14, 2014 | 03:49 PM
O/D only does exactly that. Disables overdrive. TCC lockup will still happen in third gear.
