98 ram sport
Old Apr 14, 2014 | 08:30 PM
THEMUTT62's Avatar
THEMUTT62
Default 98 ram sport
I have a 98 ram sport 1500 4wd, i changed clock spring last july n the cruise n horn quit again so i put another new 1 in n now the cruise works but the horn doesn't. Tested hrns n they r good, checked fuse n relay n both good, is it possible the new clock spring was bad? Also tested for power to horn n i had none.
Old Apr 14, 2014 | 09:15 PM
djbucky3's Avatar
djbucky3
Just an idea.. as i have no idea about the clock spring. But when testing the horn, you made sure to have someone actually pressing the horn on the wheel correct? I would assume the horn would have no power if no one is pressing it? Just thinking..
Old Apr 16, 2014 | 01:49 PM
gnelson49's Avatar
gnelson49
Swap the horn relay with the A/C clutch relay and see if it works. Test both the A/C and horn before/after swapping, might be something simple like that.
