Lower ball joint nut
Old Apr 17, 2014 | 04:46 PM
smoky614's Avatar
smoky614
Default Lower ball joint nut
well, i got the thing apart, the only thing stopping me is the lower ball joint nut just spins the spindle. I tried resting the weight of the truck on the steering knuckle with a jack, still spins. Loaded down with wd-40. Still spinning. The only thing I can think of is to cut it off, but i aint got a cutter. I would hate to have to put it all back together just to take it to a shop and get charged 300 bucks. any ideas?
Old Apr 17, 2014 | 05:42 PM
AtomicDog's Avatar
AtomicDog
Try soaking it with some PB-Blaster, Kroil or a mix of acetone/transmission fluid. Using WD-40 is like using almost nothing at all. After that's soaked in, if you have a good impact wrench along with a impact universal and socket, that will help to remove it, too. As a last option, put some heat onto the bolt with a torch to help loosen it up. Try to get it red and use some candle wax on the threads, then loosen it quickly.
Old Apr 17, 2014 | 08:23 PM
stallion81's Avatar
stallion81
If the tierod is not pulled, try that and let the knuckle hit the backside. Usually only works on install though. Otherwise go buy a sawzall. Cheaper then a shop rate. But good blades(Bosch/Milwaukee). Get both a descent sawzall and 4" angle grinder with blades/discs for under $100. Electric are cheap for both.
Old Apr 19, 2014 | 03:32 PM
smoky614's Avatar
smoky614
Ended up going with a hammer and chisel, a few busted knuckles later and she was good to go!!
Old Apr 19, 2014 | 05:11 PM
T-Ram's Avatar
T-Ram
Nice - invest in a cheap 4" grinder from harbor freight they go dirt cheap and will save ur knuckles *)
Old Apr 19, 2014 | 08:40 PM
smoky614's Avatar
smoky614
Right, definitely gonna find something!!
