96 ram 2500
Old Apr 26, 2014 | 11:17 AM
mHudson1012's Avatar
mHudson1012
Default 96 ram 2500
Okay so I just bought a 96 dodge ram 2500 4x4 and the speedo dosnt work along with it revs out to shift into 3rd gear. From my knowledge it has a 98 transfer case witch has a different speed sensor that's not in the tcase
Anyone have any ideas
Old Apr 26, 2014 | 11:22 AM
On the 96, the vehicle speed sensor is driven by a gear system in the tail of the t-case. Having the 98 t-case in there isn't going to work for you. No provision for the older style VSS. Need to swap the t-case.
For the shifting problem, and since you just got the truck.... probably wouldn't hurt to drop the pan, change fluid/filter, adjust bands, and inspect the servo springs. (it's all right there when you drop the pan.) Should take care of things for ya.
Welcome to DF!
Old Apr 26, 2014 | 01:19 PM
mHudson1012
Thanks for the response u think having the 98 tcase in there could be the shift problem?
Old Apr 26, 2014 | 04:34 PM
Real possibility. But, I would do the trans work in any event, *just because*.
