Hard to start in mornings, not the battery
Old Apr 29, 2014 | 01:14 PM
you can rent one from the parts store.....
Old Apr 29, 2014 | 01:52 PM
jmhd1989's Avatar
jmhd1989
that will work. thanks ill do a test and let you guys know what the results are.
Old Apr 30, 2014 | 12:49 PM
jmhd1989's Avatar
jmhd1989
Should be 49 PSI just turning the key to "on". If not, cycle the key again, and see if pressure comes up to where it is supposed to be. If that checks out ok, probably just a failed check valve in the regulator. You can replace just the regulator/filter assembly... but, it's 100 bucks plus..... and a pain in the keester to change. For the small annoyance it represents, just not worth it. (to me....)
is there supposed to be free play in the fitting that is on the fuel rail? It spins easy and i can pull it away from the fuel rail like 1/4 inch maybe more.
Old Apr 30, 2014 | 03:09 PM
And it doesn't leak???? A pic would be good here methinks.
Old Apr 30, 2014 | 03:30 PM
jmhd1989's Avatar
jmhd1989
So im assuming that means no? haha it doesn't pull of but i can move it. i tried pushing it on harder to see if maybe it wasn't on fully from when i did the plenum but it didn't do anything. I even used the correct tool to remove the fitting not two screw drivers like i have read about.
Old Apr 30, 2014 | 03:36 PM
Ah, that one. I was thinking you were talking about the pressure test port. (now you understand why I was having a heart attack. )
Nah, the fuel line can move around some. If it stays on, and doesn't leak, you are golden.
Old Apr 30, 2014 | 03:41 PM
jmhd1989's Avatar
jmhd1989
ooh no haha not the test port, still haven't rented the test kit. ok yeah its not leaking i just couldn't remember if it was tight before i removed.
Old Apr 30, 2014 | 04:09 PM
jmhd1989's Avatar
jmhd1989
Just went to lunch and i can't hear it prime when you turn the key on anymore. I switched the fuel system relay with the horn relay, still can't hear it prime. Another fuse to check or bad pump?
Old Apr 30, 2014 | 04:13 PM
Will the pump run while you are cranking the engine? Will it start?
Old Apr 30, 2014 | 05:09 PM
jmhd1989's Avatar
jmhd1989
yes it starts up and runs fine. i know i used to be able to hear it prime and i can't now.
