4x4/Drive train issue
Old May 15, 2014 | 04:48 PM
ballstimeballs's Avatar
ballstimeballs
I found that if I rock the steering side to side some at low speed, it will generally break loose with a minimum of fuss.
That's exactly what I have been doing to disengage mine! Do you think its possible something (maybe those same bushings you mentioned) could be responsible for the noises while driving? Maybe an axle or part of the CAD is "floating" around or something..
Old May 16, 2014 | 09:08 AM
It's possible. Some axles had bushings, I think some older ones actually had a needle bearing for the inner axle "bushing". That seems like a good idea to me. More durable. Probably wouldn't hurt to pull the cad, and see what things look like, and how much slop you have in there. (careful though, the bolts that hold the housing on like to break.)
Does the noise change when you turn the truck?
Old May 16, 2014 | 12:08 PM
ballstimeballs
I'm sure it will be a PITA, mines rusted out pretty nicely and one of the vacuum ports already snapped short.
And actually it does. I just rebuilt the whole front end (feels great!!) And even with the front DS out I can hear a light whirring sort of noise when turning the wheel to the right. Going straight or left I can't hear anything at all though.
Old May 16, 2014 | 12:19 PM
Left side wheel bearing maybe..... but, if it's new..... You aren't just being paranoid are you?
Old May 16, 2014 | 01:50 PM
ballstimeballs
I doubt it, but it wouldn't be the first time I was wrong! If they are bad I sure as hell won't be getting the same brand!
And maybe slightly the sound of mechanical issues drives me crazy!!!
hopefully I come up with an answer when I swap out the CAD!!
Old May 16, 2014 | 02:06 PM
What brand bearing did you get? Did you make sure to torque the axle nut to the proper value?
Old May 16, 2014 | 03:49 PM
ballstimeballs
I did, but I probably should have gone with a higher end brand seeing as I can't even remember the name!! I will re-check
Old May 16, 2014 | 05:08 PM
AtomicDog's Avatar
AtomicDog
I'm still thinking it may be your wheel bearing, even though it was recently replaced, as there is a wide variety of quality in wheel bearings these days. Have you tried checking the wheel bearing for play/slop?
