flex plate question for a 95 ram 4 wheel drive 46RH transmission
Old May 15, 2014 | 10:17 PM
tbird2017's Avatar
tbird2017
Default flex plate question for a 95 ram 4 wheel drive 46RH transmission
Have flex plate from a '97 360, will it work on a '95 318? Will a 318 to a 360 be a direct slot? if not what will i need?
Old May 15, 2014 | 10:56 PM
AtomicDog's Avatar
AtomicDog
I don't think it will work, as the 1997 5.9 flex plate should have weights welded to it to balance the externally balanced 5.9 engine. You will need a flex plate without weights for a 5.2. Also, check to ensure that there are no weights on the torque converter.
Old May 16, 2014 | 02:47 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
AtomicDog is correct a stock 5.9 flex plate will not work on a 5.2 engine. You can drill out the welds and take the weights off.
Old May 16, 2014 | 08:09 AM
getdown78's Avatar
getdown78
mine only had to big weight ! Drilled it and fished it out after it was all together !
Old May 20, 2014 | 09:41 AM
tbird2017's Avatar
tbird2017
Thanks guys!
