2000 1500 truck info
Old May 19, 2014 | 06:13 PM
tooltime's Avatar
tooltime
Default 2000 1500 truck info
I found a extended cab short bed 2wd 5 speed for sale at a lot for $2000.00. It has a 318 a/c(cold) vinyl seats and rubber floor mat. Not sure about windows. Has about 230,000 miles and missing the spare and jack.It is making a whistling sound and he said it is the throw out bearing goes away when clutch is pressed. I just went though with my truck and don't want to do this again. What do you guys think from what i have told about the truck.thanks
Old May 19, 2014 | 06:29 PM
High mileage, more than likely is going to need a clutch job, not to mention the plenum gasket fix.... If you don't wanna do another clutch, skip this one.
Old May 19, 2014 | 07:38 PM
djbucky3's Avatar
djbucky3
Find another, before you pay out the *** for that one. You know everything thats been on your truck, you know what probably will have to be done in the future. On a "new" truck, everything might have to be done..
Old May 19, 2014 | 07:57 PM
tooltime's Avatar
tooltime
Thanks i just want something that has a/c and my truck has play in the steering. It is a 1988 Dodge D 100
Old May 20, 2014 | 01:38 PM
ryan0714's Avatar
ryan0714
as for the a/c they make r12 substitute stuff but I never tried it. and the play is being caused by the worthless joint on the steering shaft that connects at the steering box. this is fixed by making a new shaft with new and better u-joint setup its a common problem on dodges of that generation. here is a couple links
http://www.*********.com/forums/showthread.php?t=313427
http://ramchargercentral.com/technic...orgeson-style/
http://ramchargercentral.com/technic...-joint-165445/
Old May 20, 2014 | 02:50 PM
I think you answered your own question with that statement.
Old May 20, 2014 | 10:38 PM
djbucky3's Avatar
djbucky3
100% correct.
