View Poll Results: Swapped in used heads. Use original rockers or what came on used heads?
Use 'new' rockers and pushrods, even though lifters do not match
0
0%
Use original rods and 'new' rockers even though they do not match
0
0%
Throw it together, it won't wear out anything soon...
0
0%
Voters: 3. You may not vote on this poll
Swapped in used heads...Which rockers/pushrods do I use?
I have installed fresh heads off a used 5.2 onto my 5.9. No worries there at all. Same casting, checked for cracks and vac, flat as can be and already installed.
I don't know which rockers and pushrods to use. the 5.9 rods are matched to the lifters, the 5.9 rockers are not matched to the valves. vs the 5.2 rods not matched to the lifters but the 5.2 rockers are matched to the valves.
Of course when I say matched I mean a wear pattern corresponds to a wear pattern.
Which would you use and why?
I'm no expert but I play one from time to time on the internet...I suspect the Magnum 5.2 and 5.9 engines share identical heads. There may be an R/T big valve, different rocker ratio ??? head out there somewhere.
