need help lifting 98 ram
Old May 20, 2014 | 01:54 AM
guitarman14443's Avatar
guitarman14443
Default need help lifting 98 ram
I got a 98 2wd ram i want to lift atleast 6 inches minimum, i needhelp locating the parts to do it though, does anyone have a source?
Old May 22, 2014 | 12:28 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old May 22, 2014 | 06:26 AM
RDuck's Avatar
RDuck
Lifting a 2wd?
BWAHAHAHAHAHAHAHAHA.
Use four jackalls.
Old May 22, 2014 | 10:04 AM
Not much aftermarket support for the 2wd trucks. Might be able to find spindles, get a bit of lift with a spring change. Aside from that, body lift is the next option.
Old May 22, 2014 | 10:51 AM
merc225hp's Avatar
merc225hp
One of the few that make a kit for a 2wd.
http://www.fabtechmotorsports.com/DO...SYSTEMS-c1216/
Old May 23, 2014 | 01:55 AM
guitarman14443
Thanks for the link, it was very helpful. This is probably the kit i will purchase.
