will crank but Not start. Help!
Old May 28, 2014 | 10:45 PM
  #21
Rehms's Avatar
Rehms
No oil consumption so far But the plenum is fixed and after I got all that done is when I started having this issue. It won't stay started unless giving it gas or unplugging iac So as far as plenum being fixed id say yeah it's fixed but haven't ran it long enough to tell if it's consuming oil
Old May 29, 2014 | 11:57 AM
  #22
Verify that the IAC is actually DOING something. Pull the filter housing, and watch down in the IAC well to see if you can see it move when someone else turns the key.
Old May 29, 2014 | 09:43 PM
  #23
Rehms's Avatar
Rehms
ok do i need to have em start it and see if it moves at all or just turning the key? im starting to think after i did all this plenum and all that stuff the battery died on me, for about a week it didnt have power, bought a new one slapped it in and it just wont go now lol maybe my computer is fried or the gas went bad? that is if the IAC is responding those are the only other two things i can think of to check
Old May 30, 2014 | 08:29 AM
  #24
Just turn the key to on. See what happens.
Old May 30, 2014 | 05:04 PM
  #25
Rehms's Avatar
Rehms
I'm prolly an idiot but with my iac still in my throttle body I can't see it move or feel it but it's not really visible???
Old May 30, 2014 | 05:52 PM
  #26
Yeah, it is kinda stashed inside its little housing there... According to theory, if you disconnect the battery for a bit, so the PCM forgets everything, when you turn the key on again, it will run the IAC all the way closed, to figger out where "zero" is again. Need to be paying attention though, and have a nice bright lite to see it close up, cause it will back right off some again. (if it's working properly.) You can put your finger on the part that sticks out of the throttle body, and see if you feel anything when the truck is first keyed up.
Not getting any P0505 codes?
Old May 30, 2014 | 08:24 PM
  #27
Rehms's Avatar
Rehms
No codes or engine lights that's what's weird
Old May 30, 2014 | 10:26 PM
  #28
Wonder if the PCM is smoked....
Old May 31, 2014 | 09:50 PM
  #29
Rehms's Avatar
Rehms
That's what in wondering. What all years will work with my truck anything thats 1994-97 5.9L?
Old Jun 1, 2014 | 07:42 AM
  #30
Arde's Avatar
Arde
'94-'95, '96 and up are OBDII, you need OBDI.
