Transmission shifting issues
Old May 26, 2014 | 11:34 PM
dragracer501's Avatar
dragracer501
Default Transmission shifting issues
I have a 2001 ram 1500 with the 46re and I just rebuilt it and I installed the transgo tfoddiesel shift kit but used the gas springs for it. Now my truck won't shift out of second unless I'm doing at least 65 and it'll down shift into second gear while doing 75. I don't know if something in the valve body I can change or it's not even the shift kit and I rebuilt it wrong. Any help helps
Old May 27, 2014 | 10:06 AM
Check your TV cable, make sure it is adjusted properly. If that seems ok, give transgo a shout, and see if they can shed any light on the situation.
Old May 27, 2014 | 04:08 PM
dragracer501
Ok I will do that thanks
