Brake Light On
Old May 29, 2014 | 11:00 PM
WAfrican's Avatar
WAfrican
Default Brake Light On
Hey guys I finally got my new rims installed and they're Dick Cepek DC2 16x10 and after having them mounted and aligned my brake light is now on. I checked the brake fluid and it was indeed low so I refilled it but the light is still on. Is there anything that could have caused this?
Old May 30, 2014 | 08:26 AM
Check the brake line going to the rear. It likes to rust out, and break. Usually right above the gas tank.......
Old May 30, 2014 | 01:48 PM
chromed95's Avatar
chromed95
+1 on heyyou's response. if your level was low, it's leaking somewhere, and by the gas tank is common. Check your rear drums for leaks to, the cylinders in there can give up the ghost too and leak.
Old Jun 1, 2014 | 06:03 PM
WAfrican's Avatar
WAfrican
I've checked the lines and all seem good. I've also checked the reservoir after driving it around for a few days and the fluid level hasn't changed.
Old Jun 1, 2014 | 06:39 PM
MoparMagic70's Avatar
MoparMagic70
Does your parking brake light stay on as well?
Old Jun 1, 2014 | 07:23 PM
WAfrican's Avatar
WAfrican
No its just the brake light.
Old Jun 1, 2014 | 08:46 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
may have triped the metering valve. lift rear of truck have someone hit brakes and try to turn the wheels by hand i bet the breaks wont engage in the rear
