Block test passed still burning coolant
Old Jun 9, 2014 | 07:46 AM
  #31
Snowfan's Avatar
Snowfan
Originally Posted by Snowfan
Are you sure you have a good, air-tight seal on your compression gauge hose? The numbers seem very low.
Originally Posted by 318DodgeRam
No. Thinking back now I forgot to. Does it make that much of a difference? Ill have to go back and get the tester ...
That explains the low numbers. For a compression test the engine needs unrestricted, maximum airflow. Wedge the throttle wide open, disconnect the coil and pull the fuel pump relay. Also, test with all sparkplugs removed. The numbers you posted do not add up IMO. If I were you, I would rent the compression tester again and do a dry, then wet test. My engine has 243,000 miles on it and compression ranges from 145-160.
The next step is to do a leakdown test. You can rent that also. After that is when to consider options such as heads, donor engine etc.
Best case scenario is blown gaskets. Worse case is cracked heads and lousy rings. As mentioned above, if on a budget a used engine can be found for 500 bucks and up. Nothing wrong with that option at all but be sure to get a warranty.
Old Jun 9, 2014 | 02:29 PM
  #32
318DodgeRam's Avatar
318DodgeRam
Alright. My bad you guys. Ill have to try it again soon.
Old Jun 10, 2014 | 03:43 PM
  #33
318DodgeRam
Ok guys new numbers
I held the trottle as far as it could go with an allen wrench at the carb. I did I wet test and only one cylinder went up 5 psi. The rest went down. Might be a fluke. I noticed steam coming from one cylinder. I dont think smoke. It dissipated almost instantly. Couldnt smell anything.
Drivers side/ front to back
1. 110
2. 110
3. 100 +5 during wet test
4. 120
Passenger side/ front to back
1. 110
2. 120
3. 110 steam/smoke
4. 115
Nothing is below spec. Idk.
Old Jun 10, 2014 | 06:46 PM
  #34
That's better, and since the wet test didn't show a change in results, just replace the heads, should be golden.
Old Jun 10, 2014 | 06:59 PM
  #35
Ham Bone's Avatar
Ham Bone
Yep still low but looks much better.
Put some new hesds on it.
Then do another compression test see how much it comes up
Old Jun 10, 2014 | 07:26 PM
  #36
318DodgeRam
Alright. Thanks for all the help!
