1998 Dodge 1 Ton "no interior or cargo lites
Old Jun 11, 2014 | 01:06 AM
Weanuts's Avatar
Weanuts
Default 1998 Dodge 1 Ton "no interior or cargo lites
Can I back probe (apply currant to this light circuit) to check continuity of wiring. I have checked for blown fuses and replaced headlight switch because radder rheostat was faulty.
thanks for looking
Old Jun 11, 2014 | 11:36 AM
I think the switch provides ground path. Start checking for power at the various locations.
Old Jun 11, 2014 | 04:30 PM
Weanuts's Avatar
Weanuts
Default Fixed
Thank you for your reply.
It turns out that the fuse marked "IOD" 10 Amp was the culprit. It was covered by a shield so was not readily available for checking. I do not know what caused the over draw but will have to monitor.
Old Jun 11, 2014 | 05:37 PM
Might be as simple as age. If the radio forgets everything it knew as well, IOD is the first place to look.
