trans mount replacement
Old Jun 15, 2014 | 02:24 PM
bigred95's Avatar
bigred95
Default trans mount replacement
Anyone know how to do the trans mount? Does the transmission need to be held up with a jack? And does the cross member under it need to come out to get the mount out? Thanks
Old Jun 15, 2014 | 08:28 PM
Ram Driver's Avatar
Ram Driver
You have to support the transmission, then unbolt the trans mount or cross member, or what ever is needed to get to the trans mount.
Old Jun 15, 2014 | 08:35 PM
bigred95's Avatar
bigred95
Just got it done, I was just looking at it in the most difficult way to take it off. When I realized how to do it so far that's been the easiest repair, thanks for the reply
Old Jun 27, 2014 | 10:44 PM
xplorer82's Avatar
xplorer82
which was? please explain. did you have to drop or remove the cross member at all? I'm getting ready to do the mount, extension housing seal and u joints this weekend.
about how long did it take you?
Thanks.
Old Jul 1, 2014 | 09:52 PM
xplorer82's Avatar
xplorer82
Place rear end on jack stands as high as possible to reduce fluid loss, But at a safe height..
Remove the drive shaft, if you are changing out the u joints.. Now is a good time, along with the output seal.
Unbolt the (2) 15mm nuts on the bottom of the cross member.
Unbolt the (2) 13mm bolts on the transmission mount (top plate of rubber mount)
Unbolt the (3) 16mm bolts holding the plate on the bottom of the transmission.
Place jack under the tail shaft (I used the factory jack on mine).
Remove all the bolts/nuts you loosened and raise the trans up enough to slide out the rubber mount and plate separately. you will have to wiggle the exhaust hanger out of the bushing/3-bolt trans plate.
install the new mount to the 3-bolt plate, shimmy it in place as one piece. the rest is reverse of removal.
my trans mount was in two pieces when I lifted the trans up. the metal mount plate was totally separated from the rubber mount. The truck is now free from all vibrations and other issues that was pointing toward my trans.
