Differential Fluid Change questions
Old Jul 17, 2014 | 05:06 PM
jmhd1989's Avatar
jmhd1989
Originally Posted by abdodge1500
UPDATE: well my truck's rear end is shot, we opened it up and there was giant chunks of metal from the ring gear and clutches at the bottom. So we're putting in an axle from a truck with 80,000 miles on it. To the tune of $1,200. Man this sucks.
I just did my fluid change and found big chunks of metal as well. but it was running fine no squeal clunk grind or anything. was yours sounding/feeling fine too? there was a ridiculous amount of rtv on my rear so i was thinking maybe someone did the repair prior but didnt get all the broken metal chunks out. Wishful thinking maybe.
Old Jul 17, 2014 | 09:51 PM
JSTMoto's Avatar
JSTMoto
Ahh the 'ol terrible limited slip clutch pack design strikes again....
Some people get lucky and the clutch pieces fall to the bottom and stay there until you clean them out. Others aren't so lucky. If you've got pieces in there, I don't recommend waiting to fix it. A $100 diy clutch pack rebuilt could turn in to big bucks fast.
Old Jul 18, 2014 | 07:38 AM
RDuck's Avatar
RDuck
$1200?
Seriously?
You are installing it yourself right?
I think your getting screwed.
A used rear differential is only a couple hundred bucks or so.
Takes a couple hours to swap with hand tools and a floor jack.
Old Jul 18, 2014 | 11:08 AM
jmhd1989's Avatar
jmhd1989
It looks like one of the many triangular curved tabs broken down from some part of the clutch pack. How would i change that? do you have to go from the sides or just mess around in the pumpkin?
Old Jul 18, 2014 | 12:22 PM
djbucky3's Avatar
djbucky3
Originally Posted by Ham Bone
oh well.
that sucks man
How much we talkin?
Old Jul 19, 2014 | 12:34 AM
JSTMoto's Avatar
JSTMoto
I just responded to your thread with a link that does a good job showing the process with pictures to get to the clutch pack. I can't say for sure if there's an easier way to do it without pulling the carrier.
Which piece(s) does it look like? This is only one side of the clutch pack too btw.
Old Jul 21, 2014 | 05:27 PM
jmhd1989's Avatar
jmhd1989
Thank you it was definitely one of the clips. So after some research i just decided to pony up and get the Detroit True Trac Limited slip put in.
