Ugh...clogged cat?
Old Jul 7, 2014 | 01:55 PM
jmhd1989's Avatar
jmhd1989
can your cat be bad without sending a code? if so how would you test it?
Old Jul 7, 2014 | 02:26 PM
Yes, cat won't necessarily set a code. If the truck runs better with the front O2 removed from the exhaust pipe, cat is bad.
Old Jul 7, 2014 | 08:39 PM
DodgeFanMP's Avatar
DodgeFanMP
Default Wow, great advice. I'll call around. Thanks!!
Originally Posted by archemedes74
check with your muffler shop before you buy, we have one here that installs a magnaflow for less than you can buy it at the parts store
Thanks!
Old Jul 7, 2014 | 08:43 PM
DodgeFanMP's Avatar
DodgeFanMP
Default I've heard that time and time again...I will give this a try if I can get the O2 out.
Can you give me the idiot's explanation on why this is so? Does removing the pre-cat O2 sensor simply give the exhaust back pressure from the clogged cat somewhere to escape, making the exhaust less restrictive, or does the exhaust back pressure actually foul up the O2 sensor's readings and cause the fuel trims to get out of whack? Both? Something entirely different that I'm missing altogether?
Thanks!
Old Jul 7, 2014 | 08:45 PM
First option. The engine is a giant air pump, if the air has nowhere to go, it can't take any more in, and runs like.... well..... crap. Pulling the front O2 just gives it someplace to go. Bear in mind, it is still rather restrictive, but, it will at least run that way.
Old Jul 7, 2014 | 08:49 PM
djbucky3's Avatar
djbucky3
Anyone else think HeyYou should start a thread or book or something of everything he knows?
Old Jul 7, 2014 | 08:52 PM
DodgeFanMP's Avatar
DodgeFanMP
Default Makes perfect sense. As usual, thanks!!!
You, sir, are very kind to offer so much help. Folks like me appreciate it greatly!
Old Jul 7, 2014 | 08:53 PM
DodgeFanMP's Avatar
DodgeFanMP
Default Sounds good to me!
I'd pre-order that in a heartbeat!
Old Jul 7, 2014 | 10:18 PM
djbucky3's Avatar
djbucky3
Agreed, 100%
Old Jul 7, 2014 | 11:34 PM
Spillage's Avatar
Spillage
It would be fact filled, for sure... but I wonder if it would be found in the comedy section, as the secondary commentary is guaranteed to provide a laugh.
