Cruise control not working
Old Jul 5, 2014 | 11:09 PM
Lineman12's Avatar
Lineman12
Default Cruise control not working
I need some help!! I have a 98 12 v dodge diesel and my cruise control went out a few weeks ago. I have done some research on what to look for.. I have check the vacuum line for the servo and it was good, I replace the switch where the brake pedal is. The cruise control light comes on but it won't set or anything. So what do I do ? Start replacing parts until I fix it or if someone has had the same problem that could relate to this that would be helpful. Thanks kirk
Old Jul 6, 2014 | 11:39 AM
Welcome to DF!
Need to see if the cruise switches are working. They just modify a signal from the PCM, and the PCM interprets it from there. PCM sends a reference signal, switch just routes it thru various value resistors to clue in the PCM what you want. Make sure that part is working first.
Old Jul 6, 2014 | 06:48 PM
Lineman12's Avatar
Lineman12
Ok so how do I get the steering wheel cover off. So I need to check the clock spring.
Old Jul 6, 2014 | 07:46 PM
Test at the PCM connector. That will tell you if you have a break in the wire somewhere.
Old Jul 7, 2014 | 12:47 AM
Lineman12's Avatar
Lineman12
Ok I will try that thanks
Old Jul 7, 2014 | 06:23 AM
Lineman12's Avatar
Lineman12
At the PCM which of the three connecter do I test ?
Old Jul 7, 2014 | 09:57 AM
You can download the factory service manual from here. Wiring diagrams are in there, and will let ya know which wires, and what resistance values you are looking for.
