Yea I checked belt first thing I was thinking the same thing. But it was good. I just don't see a vehicle being able to over heat in 5 mins with no ac on and radiator fluid is full and looks good
Have you verified it's actually getting that hot and not just a gauge malfunction? That's awful quick. I drove over five minutes before with no pump, engine already quite warm. Is it possible to have the wrong pump? It usually takes longer than five minutes for the thermostat to open.
I'm gonna check everything first I was just wanting to know the temp gauge automatically starting at 140-150 and not on cold what would cause that also
No it does not. It should start all the way to the cold side and move up as the engine warms. If you unplug the sensor the gauge should fall to cold. If it doesn't then you might have a short somewhere.
Another thing to watch for with new sensors... They can be bad/off from the factory. I went through 3 before I got one that would read in the proper range, and it still shows about 15 degrees above true temp..
