Differential Capacity emergency
Old Jul 17, 2014 | 04:47 PM
jmhd1989's Avatar
jmhd1989
Default Differential Capacity emergency
So my service manual and royal purple said my diffs take 2.45 qts. i got to about 2.10 and it started coming out the fill hole. whats the deal? i dont want to over fill and right now it is literally at its max, right level with the base of the fill hole
Old Jul 17, 2014 | 04:54 PM
Ham Bone's Avatar
Ham Bone
You just fill it up to right below the full hole. Ovefilling will cause gear oil to come pouring out everywherreand overrun your seals
Old Jul 17, 2014 | 04:57 PM
jmhd1989's Avatar
jmhd1989
so if it is sitting level and not coming out the fill hole its ok? or should i suck some out? so i was adding the .45 when it started coming out of the fill hole so it stopped leaking right when it got just a hair below the hole obviously. that too much in there?
Old Jul 17, 2014 | 05:02 PM
Ham Bone's Avatar
Ham Bone
JUst below the fiill hole. like once it start barely coming out of the fill hole youre good. Stop. Put the plug back in.
Old Jul 17, 2014 | 05:03 PM
jmhd1989's Avatar
jmhd1989
ok thank you, i didnt want to drive it if it was at all off
Old Jul 17, 2014 | 11:37 PM
Drive is a LITTLE BIT, then recheck the fluid. Sometimes it takes a bit for it all to go where it wants. Driving it with low fluid gets expensive quick.
Old Jul 18, 2014 | 03:04 AM
ryan0714's Avatar
ryan0714
yup just fill her till she drools then plug it back up. also add some rtv to the plug lip so u dont have that ugly leaky plug
