mpg increase
Old Oct 20, 2005 | 02:44 AM
steve05ram360's Avatar
steve05ram360
Default mpg increase
swapped the rear diff fluid and the 5sp tranny fluid to Red Line fluids and saw a 3.7% increase in fuel economy... 18.2 -> 18.88 mpg. I went ahead and picked up some more rear diff fluid for the wifes truck and the Ram...
Old Oct 21, 2005 | 03:00 AM
shott8283's Avatar
shott8283
Default RE: mpg increase
i wonder why that is? will the red line stuff run with the mopar lsd additive? that is if you got the lsd
Old Oct 21, 2005 | 12:37 PM
steve05ram360
Better lubricating properties of the oil. the less friction you have, the less HP turning the gears takes from the motor.
Also, you wont need the additive if you get the right red line fluid, there is some that comes with it already.
Old Oct 25, 2005 | 02:55 PM
steve05ram360
another update... for whatever reason, mpg has gone from 18.3 originally in the Dak to 18.8, and now up to 19.1 mpg... no changes in driving habits in the Dak, could be a different formulation in the gas for winter, i'm not sure but just thought i'd update everyone.
Old Oct 25, 2005 | 07:53 PM
Tani1500's Avatar
Tani1500
whats that stuff called and where can i get it. is that like the same stuff as the synthedic royal purple trans fluid?
