Lower shock bushing/bolt size
Old Aug 5, 2014 | 10:01 PM
CoryVolkenant's Avatar
CoryVolkenant
Default Lower shock bushing/bolt size
anyone have a OD dimension of the front lower shock mount bolt?i believe my shock bushings are too large and my shock is just flopping around even as tight as i have it and also what is the length of the lower shock bushing > hoping someone has one or both laying on a bench so i dont gotta pull it apart, want to call rough country tomorrow and see if they make or i can get the dimensions of the bottom of there shock and see if maybe factory bushings or see iif i can find a better fitting aftermarket busing, thanks in advance
Old Aug 6, 2014 | 11:10 AM
Lower shock bolts are supposed to be torqued to like 110 ft/lbs..... No clue what size they are.
