Best Ways to get better MPG?
Old Oct 30, 2005 | 01:14 AM
cableguy's Avatar
cableguy
Default RE: I got it!!
You got 400 + miles out of a tank in the first place?? If I break 300 I,m doing cartwheels, and 325 makes my week. BTW, I fill up about every other day.
Old Oct 30, 2005 | 12:17 PM
steve05ram360's Avatar
steve05ram360
Default RE: Best Ways to get better MPG?
ORIGINAL: Ramtuff
Adding acetone to your fuel will also net a good mpg increase. The following are my results using acetone in my Ram...
27 gallons of gas @ $2.80 for the cheap stuff = $75.60
I can get 32 oz. of acetone for about $5. So 4 oz. into 32 oz. would be 8, so divide $5 by 8...it's 62.5 cents more per tank of gas.
I was getting 16 mpg x 27 gal = 432 miles per tank.
I'm now getting 19 mpg x 27 gal = 513 miles per tank.
It's about a 19% increase in mileage.
So, $75.60 divided by 432 miles = 17.5 cents per mile.
$76.23 (fuel and acetone) divided by 513 miles = 14.9 cents per mile.
17.5 minus 14.9 equals a savings of 2.6 cents a mile, and a savings of $13.38 per tank.
I drive about 16,000 miles per year. 16,000 divided by 432 miles = 37 fill ups x $75.60 = $2,797.20 dollars per year on gas.
16,000 divided by 513 = 31 fill ups x $76.23 = $2,363.13 for gas per year.
Basically, that's a $434.07 savings per year that I can spend elsewhere, plus my truck starts faster, runs smoother, and throttle response is improved.
Using acetone to increase mileage
Acetone trick
here's a thread on the acetone topic... worth reading.
http://www.dodgetrucks.org/forums/viewtopic.php?t=63390
Old Oct 30, 2005 | 02:39 PM
1500sport's Avatar
1500sport
ORIGINAL: cableguy
I want to know how he is gettting 27 gallons in because if it is a shortbed it only has a 26 gallon tank and hopefully he's not running it dry everytime.
Old Oct 31, 2005 | 12:13 PM
bamory's Avatar
bamory
So you basically put fingernail polish remover in your gas-tank?
Old Nov 13, 2005 | 01:44 AM
Ramtuff's Avatar
Ramtuff
ORIGINAL: 1500sport
ORIGINAL: cableguy
On the Star data print out from the dealer, it lists a 27 gal tank for my truck. Also, why would I have to be running it dry? You do know how to figure out the range of a vehicle right? MPG multiplied by the number of gallons the tank holds. Where you decide to fill up the tank has no bearing on determining range.
Old Nov 13, 2005 | 01:45 AM
Ramtuff's Avatar
Ramtuff
tar
ORIGINAL: bamory
Yup, and you probably have too without knowing it. Ever use a can of octane booster or combustion cleaner? They contain acetone.
Old Nov 13, 2005 | 04:35 AM
hometheaterman's Avatar
hometheaterman
ORIGINAL: V10
ORIGINAL: 01ramclassic
Having the tailgate down does work don't it?
Nope. A tonneau cover or topper will help MPG, but leaving the tailgate down to increase MPG is a myth. It's also illegal in many states.
I have a tonneau cover and still get crappy mpg I have read the exhausts also help it a little which I don't know that it is true but damn I'd hate to see what kind of milage I got without these two things as it is horrible now. Of course the tires and small lift don't help it but still.
Old Nov 13, 2005 | 12:16 PM
HankL's Avatar
HankL
The adding acetone to gasoline deal is another 'Internet Myth' that just won't die.
I consider it a 'Virus' without software code because many people who will go out and try it, will spill some acetone on their paint and ruin a spot.
Gasoline already has acetone in it. Acetone is one of the many 'natural' products that make up crude oil. Benzene, Toulene, octane, hexane are all their in the 'crude' mix.
If you want to improve your MPG with a gasoline change and are willing to go to extra effort, just begin weighing exactly one gallon of gasoline from the various filling stations near you.
As a general rule, the gasoline that weighs the most per gallon (highest density) will have the most heat (calories/liter or Btu/gallon) and more heat per gallon will give slightly better MPG.
Diesel fuel weighs more per gallon than gasoline and that is one of several reasons diesel engines get better MPG - the main other reason is compression ratio.
Gasoline with added ethanol weighs less per gallon than "pure" conventional gasoline.
89-93 High octane gasoline with more benzene/toulene percentage will weigh more per gallon than 87 octane, but if they make higher octane mixes with added ethanol it will weigh less and get less MPG.
Old Nov 16, 2005 | 05:58 AM
arsenic's Avatar
arsenic
does the k&n filters improve mpg or is in the intake systems?
Old Nov 16, 2005 | 09:15 PM
bamory's Avatar
bamory
I am trying the acetone test on my truck, I will be the guinney pig here, i half expect some sweet smelling exhaust but very little other than that, maybe a cleaner combustion chamber. Will keep ya updated
